Hi again. I hope you all will excuse-me for posting so many times in these days. But I'm installing my engine and am totally newbie. My engine is O-320 D1A, bought from Van's 1 year ago.
I tried to install, and actually installed, oil fittings "from" and "to". One is very simple, since there is optimum access (the upper-left one). The other (below the oil filter) is getting me crazy.
I disinstalled MT propeller governor to gain more access to the oil port and grinded part of a crowfoot wrench. After much pain, I managed to torque fitting as follow (see image) and I guess the direction where it points is not the typical one (even if hose will reach oil case). My torque wrench reads about 140 inch./lbs. while the red handbook states 150/250 inch./lbs.. Problem is that I have no more access to torque it and even if I could torque more, it would need at least half turn more to become accessible again for hose installation. In this case, I guess it would be over-torqued.
Apart from this, I would be curious to understand how you others managed to have a clean install of the said fitting. The only way to have good access to oil port would be removing all the base of the oil filter, which seems to me impossible because the lower-left nut cannot be removed since the bolt touches the body of the filter.
This is a photo from above, to make you understand the big picture...
[/IMG]
![209g7s8.jpg](/community/proxy.php?image=http%3A%2F%2Fi35.tinypic.com%2F209g7s8.jpg&hash=94e4b8965acda4d3fac1d7bbea86c7c5)
![xefnk0.jpg](/community/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi33.tinypic.com%2Fxefnk0.jpg&hash=a21392f1a3f943b43d545436c0fabce9)
