WillH
I'm New Here
Patron
I believe I have an oil pressure sensor issue and I’m having trouble finding a replacement. Aircraft spruce said the part number is discontinued. Can someone point me in the right direction? I’m attaching a photo of my current sensor.
Rv14 YIO-390-exp119
Garmin has moved to a different type of oil pressure sensor, which uses the same connector. The new part number is 011-05783-30. If you install one, be sure to change your oil pressure sensor configuration to "GPT 150G".
any hints as to who manufactures it? Doesn't look like anything in the Sensata catalog...
Thanks for your help, the new sensor fixed the issue!
