Steve Sampson
I am struggling through the issues of a new aircraft engine and instrumentation. Not to say it is not fun!
The attached graph is from the second (and last) flight on Monday. What concerns me is the oil pressure ( O-320 )is showing as 104psi at about 150F. This is over the normal maximum. In the factory, the engine did 2 test runs of 30 mins at 2600 rpm where it recorded 76psi at 145f and then 85psi at 130F on 100 weight Shell oil. I am using 80 weight Total.
So what I am puzzling about is this:
Do I have an engine problem? Can the oil pressure relief adjust itself? This seems unlikely to me but I dont want to bust the cooler.
or,
Do I have an instrumentation problem? Clearly i need to get a second gauge on the engine but I need to fly it to the equipment ideally.
The individual at Aerosport Power is away for a few days so I cant get help there. I cant find anything wrong with the new instrumentation. The claims there are is that it is normally accurate.
Am I right in thinking that it will be the instrumentation when the problem is finally uncovered?
PS Also, anyone know why a new engine would show such different pressures on its test, or should I assume it was ajusted between tests?
or,
