DanH Legacy Member Mentor Aug 25, 2022 #1 Doing some research. Save me a trip to the airport please. Do you have a Champion or Tempest oil filter handy, preferably a 48110 (short body) or 48111 (long body)? I need the gasket dimensions...OD, ID, and thickness
Carlos151 Well Known Member Friend Aug 25, 2022 #2 Here's what I've got for a Tempest 48108-2 filter (same dimensions as a 48110-2 just has a female thread instead of a male thread): 2.908" OD 2.480" ID 1/8" thick
Ironflight VAF Moderator / Line Boy Mentor Aug 25, 2022 #3 Using fractions, I get 2-15/16” OD, 2-7/16” ID, 1/8” thick….
DanH Legacy Member Mentor Aug 26, 2022 #4 Thank you gentlemen. Paul, yours was a used filter, gasket perhaps flattened out a bit due to previous compression? Last edited: Aug 26, 2022
Ironflight VAF Moderator / Line Boy Mentor Aug 26, 2022 #5 DanH said: Thank you gentlemen. Paul, yours was a used filter, gasket perhaps flattened out a bit due to previous compression? Click to expand... Yes, used - it was what was sitting on the bench at 10 p.m.
