FireMedic_2009
Hi everyone
I was wondering if an air filter should be used for the oil cooler duct? I have a 4” scat coming from rear baffle over the #4 cyl. I’m thinking over time the oil cooler will become clogged with dirt and debris causing the oil temp to increase. The oil cooler is larger than the normal size one and is a very tight fit and would take over an hour to remove oil lines, cables, brackets to get to the cooler to clean. Nine months ago I removed an a/c coil to clean it and the fins are so tight that when I tried spraying water through the coil hardly any water would go through even after it was cleaned chemically.
