I need to buy an Oetiker outfit, pliers and clamps for some fuel lines. Things have gotten confusing, they have clamps for air, CO2, welding gas and water. What clamps are what is needed for fuel lines and where is a good place to buy them?
Personally, I cringe when I see automotive style filters/hoses/clamps on aircraft fuel systems. Is the 12 designed this way?
......What clamps are what is needed for fuel lines and where is a good place to buy them?
Personally, I cringe when I see automotive style filters/hoses/clamps on aircraft fuel systems....
Since I am putting in an automotive engine, why should the filters, hoses and clamps that work flawlessly in the automobile not work in the air? It is in fact an identical system being used in the Around the World flight of the Sling with 914 Rotax.
I don't like automotive engines in airplanes so I guess its to be expected that I don't like automotive "accessories" in them either
I try to take the "experimental" out of experimental aircraft as much as possible, guess I'm just chicken in my old age.
I can appreciate your position, which is more the norm, and I the abnormal. In my old age I feel more a need to experiment!
Aviation quality firesleeve band clamps and the tool necessary to set the clamps can be purchased from several vendors including Wicks and Spruce:
http://www.aircraftspruce.com/catalog/appages/aqfiresleeve.php
http://www.wicksaircraft.com/catalog/product_detail.php/pid=8909~subid=10606/index.html
http://www.aircraftspruce.com/catalog/topages/aeroquipClamping.php
Rick, I purchased the cheap band-it clamping tool version (24 bucks) but for the life of me cant figure out how to use it....go figure. the instructions are a bit nebulous to say the least. any advice?
Granted those clamps look nice, but I don't really get it. What's wrong with a standard, properly sized, hose clamp, which has the advantage of being removable with nothing more than a screwdriver, iis readily available at any hardware store, and can be re-used multiple times. Mine seem to be working just fine...
Erich
Back when the Bicycle boys first built their plane there was no experience about what worked on an aircraft and what didn't. We have over the last 100 years learned that some equipment is better than others.
Don't be so quick to throw out all the aviation hardware in favor of automotive stuff. Some of it may work most of the time and some may not, but the certified airplane guys have learned over the years, and usually the hard way what works. It makes good logical sense to use the same stuff if you are going in the air. Cars and Airplanes are not the same.
