b17fe Well Known Member Jan 5, 2009 #1 What size hole for the wire connector do you use on the Odyssey battery terminals? 5/16" ? (same as master relay) I'll be using #2 awg wire but don't have the battery yet. Thanks!
K Ken Well Known Member Jan 5, 2009 #2 5/16 is big. Use a 2-4 terminal if you are using 2 awg. The posts are metric but 3/16 to 1/4 works. Ken
Ron Lee Well Known Member Jan 5, 2009 #3 I think it is M6. http://www.odysseybatteries.com/battery/pc680series.htm http://www.odysseybatteries.com/battery/pc925series.htm
