brayski98
I flew this past weekend and had an odd issue with a misfire on an O-320/carb in the -6A. Not sure if it was a backfire or afterfire.
Normal startup. Everything looked as expected during run-up prior to taking off. Normal takeoff and climbed out starting at around
1200 fpm with full fuel. 10 minutes later at 7500 feet, it sounded like a small bang, like the engine had misfired. It happened twice more and
I thought about landing and checking things. But right after that it smoothed back out. I kept a close eye on it and stayed close to
airports and had no more problems. As I was leaning the engine, I noticed #2 being about 50-100 cooler than the others. Continued the flight
for another hour and no problems. On the return flight at 8500, no issues either. The engine has 2 slick mags and I replaced the spark plugs
about 5 hours ago after seeing a problem on run-up with running rough on the right mag check. I did gap the plugs before I put them in.
I?m thinking it still sounds like an ignition problem, but wasn?t sure if it could be a fuel contaminate, or ???
I am tempted to at least replace the plug wires, but thought I?d gather ideas from the group before I just start replacing items.
