depends eh!?
I believe this is what I have now, an A3A....converted to straight riser intake sump...making it an A3B.
......do you plan to use a C/s prop? I like that it can run low octane fuel. :)
sorry about the formatting. go to
http://www.meyette.us/LycomingEngineNumbers.htm
for the original.
Model HP T/O RPM Fuel C.R. DESCRIPTION Suffix
O-320-A1A 150 2700 80 7.00:1 Controllable propeller, 25 degree spark advance Bendix S4LN-20 and S4LN-21 Magnetos -27
O-320-A1B 150 2700 80 7.00:1 Same as -A1A with straight riser in oil sump and -32 carburetor -27
O-320-A2A 150 2700 80 7.00:1 Same as -A1A but fixed pitch propeller -27
O-320-A2B 150 2700 80 7.00:1 Same as -A2A with straight riser in oil sump and -32 carburetor -27
O-320-A2C 150 2700 80 7.00:1 Same as -A2B with Retard Breaker Magnetos -27
O-320-A2D 150 2700 80 7.00:1 Same as -E3D but with conical mounts and 0-320-A sump and intake pipes -27
O-320-A3A 150 2700 80 7.00:1 Same as -A1A but uses 7/16 in. dia. propeller bolts -27
O-320-A3B 150 2700 80 7.00:1 Same as -A3A except for straight riser in oil sump and -32 carburetor -27
O-320-A3C 150 2700 80 7.00:1 Same as -A3B except for Retard Breaker Magnetos
Straight Riser
I was told a straight riser wouldn't work in a 9A because of the mount interference. You have a straight riser sump installed OK?
Gary
Sump
So if I read the chart correctly it will fit a 9A without changing the sump.
It is a plus that it will take a constant speed prop.
At 7:1 I would feed it Mogas !
David
need some experts to respond
as i understand it the curved riser tubes get in the way of the mount; the straight has them more forward...but don't quote me on the semantics.
Get an engine guy to verify.
also you want to know if the plug is in the (hollow) crank before you hang a C/S prop on it, and can't get oil to it!
ditto the expert required.
B1B Straight Riser
Still not certain if a B1B will fit in the 9A. If the straight riser oil sump is the problem, how difficult and expensive is it to change? Any expert advise out there?
Gary
Gary
For an "A" model RV, the straight riser sump is the one you need.
I already replied to the other thread you started HERE
