RV6_OKLA
The o-ring for my Andair GAS375 gascolator broke. It takes the ORO375 o-ring which is hard to find. Any source suggestions for compatible o-ring?
O-ring for Andair Gascolator
As an update, the Andair 375 gascolator uses a 2mm x 39mm(outside diameter) 75 Viton black o-ring. I could not find any available from aviation vendors so I tried McMaster Carr. They carry a 75 Viton black 2mm x 35(inside diameter) which is the same as the 2mm x 39(outside diameter). They come in a pack of 10 for $16.50 plus tax and shipping.
I applied a very thin layer of silicon grease on the o-ring and put it on the gascolator bowl. It was the perfect size and assembled very easily with the gascolator body. I pressure tested with the boost pump and it did not leak.
Andair Gascolator O-rings
I got a bunch of these from Andair in England.
PM me and I'll send to you for cost of postage.
John P.
