Doug Rodrigues
Active Member
I'm accumulating engine parts piecemeal to have enough to assemble a functioning engine. Question: With what was originally a wide deck engine case, can narrow deck cylinders be used on that case with the narrow deck crankshaft? Is there difference between the N/D and the W/D crankcases other than the W/D has a reputation of being more prone to cracks? Is the accessory housing identical for both crankcases?
