Not sure if I have a problem or not. My engine (an ECi I assembled), typical O-360, carb, 8.5:1 compression pistons, lightspeed 2 and mag for ignition, fixed prop, primer to 3 cyl with electric solenoid switch. When I start it cold, I use the lightspeed and the mag is off. I hit the starter and then basically hold the primer switch on until the engine starts (probably about 15 sec). Once it starts, I turn the mag on. The engine runs great and will exceed the 2700 rpm limit on the prop in level flight at 2500'. Once warmed up, no primer is needed and the engine starts in about 5 sec. I initially thought this was a cold weather thing, but now that temps are in the 60's I've tried going back to no primer, and also tried with 5 sec of primer, but still have to hold the primer on while cranking to start it. I can definitely live with this, but just wanted to throw it out there for any ideas.
thanks
By the way, 40.3 hrs on the airplane and securing Phase I until I get some aerobatic training, when I'll put it back to get those added to the limitations (only rolls so far)![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks
