P pilot28906 Well Known Member Feb 7, 2018 #1 Can an O-360-A1A be converted to FI and horizontal induction? If so, what would be a ball park price? Thanks
N941WR Legacy Member Feb 7, 2018 #2 Check out Airflow Performance for the price of fuel injection. As for the sump swap, that all depends on if you buy used or new and do the work yourself. The change is fairly easy, so don't be afraid of doing it.
pa38112 Well Known Member Feb 8, 2018 #3 FI; Yes - $3,200, and Horizontal Induction: Yes - $1,500. Ballpark numbers.
jthocker Well Known Member Feb 8, 2018 #4 AvStar ! Don?t discount using AvStar. Standard on new Lycomings. Balanced injectors out of box and you can actually bolt your airbox or snorkel to the servo body instead of a clamp ring. http://www.avstardirect.com
