docrichardson
Member
I took the advice from a thread to construct the rudder first, and all seems to be going well. I have a question about the type of rivet used to hold the nut plates onto the R-608PP reinforcement plates attached to the R-902 spar. I don't see where the specific nut plate is called out, either, along with the rod end bearing. Any help is appreciated!
