Flying Scotsman
Stupid question, I realize, but...Is there such a thing as a nut (just a regular old nut) a la AN924s, but for NPT threads?
I don't know if it is technically an NPT nut, but I have used something like this in my homebrewing setup. It was threaded onto a piece of pipe and used to seal an O-ring against the side of a kettle, IRRC.
Here is a picture of the setup curtousy of MoreBeer.com. The item in question is just to the left of the two washers and orange O-ring. You can sort of see how it would be used to apply pressure to the washsers and seal the O-ring against the inside wall of a cooler.
As mentioned before, it won't create a seal on the pipe threads. Hope that helps.
Would something like this help?
Gives you a female NPT both sides of your firewall. I'm using one to take my manifold pressure line into the cabin. The Van's restrictor wouldn't fit in my cylinder head so I put it the other end of the hose, connected to this bulkhead fitting. Also made it relatively easy to split the manifold line in the cabin for the EMS and LightSpeed EI.
http://www.legris.com/Legris_ecom/RechercherReferencesTypeArticle.do?codeReferenceRecherche=1871%2000%2011&codeReferenceASelectionner=1871%2000%2011&codeActivite=BP&codeGroupe=05&codeFamille=06&codeSousFamille=01&codeTypeArticle=1871&codeFiliale=uk&codeLangue=en_GB
