MartySantic
Has anyone cut 1/2" off the flap handle spring to lower the required thumb pressure? Did it help or should I look for another spring?
I also wound enough thick tape (rescue tape) into the gap just below the top of the flap “push button” to mostly fill the gap. Did this after “biting” my hand (web of skin between index finger and thumb) between the flap button and flap bar. You’ll only make that mistake once![]()
In case anyone else ever wants to alleviate the possibility of getting pinched, the button part was redesigned many years ago to do away with the gap that causes the pinch point and it it very inexpensive to buy.
Scott, do you have a part number on hand?
-dbh
