While rigging my RV-4 ailerons, I'm running into a problem of not having enough aileron travel. Book says to have 25 up (minimum) and 15 down (min). I'm currently getting about 21-22 degrees up and 15 down, so even my total range of motion is not where it needs to be. This is with NO control stops installed.
I started by following the plans - which say to displace the bellcrank 1 and 3/16 inches at neutral stick position. I then adjusted the length of the pushrods (slightly by adjusting the bearings in or out) to get the ailerons neutral.
When I deflect the stick full left or right I reach the limit of the stick travel before I get the desired total deflection of 40 degrees minimum.
Any ideas???
Rick
Any ideas???
Rick
