I'm reading the install manual for my SL30 and it says that both sides (Nav&Comm) of the radio are protected by a built in fuse, one for each side and of differing values. So for example the manual says the radio has lets say a 7 amp built in fuse on the comm side and should be protected by a 5amp fuse on the down leg. Does that mean that there should be a fuse on the ground side of the radio? I'm just not sure what ?Down Side? means.
