Guess I will post this as a new thread. Just adding it onto an existing thread resulted in answer to wrong subject. I also did a search(s).
In a different thread, a photo shows the nosegear swivel stop plate WD-631 mounted with the "stops" portion mounted to the rear. The Van's drawing I have (for the older gear leg and fork) shows the plate with the stops forward.
Which is right or more correct? Or is this a new fork versus old fork thing?
It would seem the difference would just be less angular displacement of the trailing nose wheel.
