Just repacked all bearing on my 6A, nose wheel just doesn’t seem right… if axle bolt is tightened enough to prevent aluminum spacers from turning the tire/wheel turns but you cannot spin it a full rotation… if the axle bolt is loosened enough to get free tire movement, the spacers also turn against the yoke. I certainly don’t remember this issue from my nose gear leg rebuild or the last bunch of hours… any ideas?
