Lycosaurus
Hello All,
While I already have the newer fork assembly (I think we got the finish kit in early 2006 ... has it been that long already?), the nose wheel service bulletin got me thinking about this again.
First, I had already drilled holes in the fork and bushings to prevent their rotation. Great idea (see earlier posts from other builders suggesting this).
When placing the wheel in the fork, I had to pry open the fork to allow the wheel/bushing assembly to slip in. It’s kind of a pain, with having only two hands. With the axle bolt inserted, I found it difficult to rotate the wheel. Now Vans says that this will loosen up with time, however I have read from others that rotation remained stiff. By stiff, I mean you cannot spin the wheel more than about a 1/4 turn.
My belief is that such a stiff wheel, when encountering some pavement irregularity, will impart this load to the nose-gear leg. Upon a landing, for instance, the wheel will be balking rotation and transferring the subsequent rear facing force to the nose-leg. Additionally, if you were to bounce the nose-wheel at the forks resonant frequency (or sub-multiple), this would magnify the forks travel. Under the right/wrong circumstances ... well, we know what happens.
Maybe my fork is a unique case, being so tight. If yours is like mine however, you may want to consider the following:
Here's what I did. I measured the fork internal width: 4.55". The wheel with bushings is approximately 4.65" in width (took some differential measurements) . With wheel removed, I placed an old car scissor jack (with wooden pieces to protect the fork), and opened it up to just a little larger than 4.65". It's tough to gauge, since the fork tongs are very springy. I had to try several times and stopped once satisfied with my width measurement.
Now I get to easily install the wheel with the bushings without having to pry the fork open. Put in my anti-rotation bushing screws, and finally the axle bolt. I can now have the tire rotate multiple turns. I then tighten the axle nut until I get the desired amount of rotation; I now have full control! I will have plenty of time to research the exact preload I need on the bearings (I think it is ¾ turn … someone can chime in with some values).
Maybe one reason that some nosewheel RVs are more prone to flips than others is due to some forks being tighter. I would be interested to know how many people have observed the tight fork when inserting their wheel/bushing assembly.
Just my thoughts. Comments appreciated, as I only know enough to get myself into trouble J
