Are there any differences in length between nose gear legs of the 6,7,8,9 series tri gear aircraft. I will be using the leg on a non RV installation and prop clearance is the issue.
Thanks.
Asked Vans about 7A gear for my 6A when the 7 was first introduced at Oshkosh. Kind of liked the way the 7A or 9A sits on the ground.
Not interchangeable.
