Paul Austin
Active Member
Hi all
Today i was installing the taper pin in my nose gear were the bolt normally goes. To start with i couldnt get the taper reamer to cut and when i did i some how stupidy let the reamer cut to deep
so now the head of the taper pin actually goes below the surface of the mount when tightend. Does any one have ay ideas how to fix this or can i get an oversize taper pin or did i just stuff my engine frame and nose gear![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
