Nose gear stake.
I'm a bit (maybe more than a bit) cautious about mods so I did a bit of research on this one. I contacted several builders who had used 10-32 stake screws in the nose gear in both 6As and 7As. There were no reports of problems. One builder had staked a 6A at the 3 OClock position 6 years ago with no reported problems and had more recently staked a 7A in the same position.
Then I asked Vans for comments. They said that there were many examples flying with the stake and they had not heard of any adverse feedback. They were not opposed to the concept. They did suggest however that a smaller screw could be considered and there is merit in that recommendation.
In the end however I went with a 10-32 AN countersunk structural machine screw due to precedence, availability, and the fact I could get it in 100 degree CS head and with
exactly the right grip length. It's also 125,000 psi so no chance of failing.
The exact screw is an AN 509-10R12 or an MS 24694-S54.
I have attached a photo of the final arrangement. The screw is prevented from backing out by the fairing bracket that eventually covers the screw head. The forks are snug reamed and the mushrooms are tapped. You'll need a #21 drill and a 10-32 tap. It's easier if you have a tapered tap to start with and follow up with either an intermediate or bottom tap.
The best way to do this is to temporarily bolt the mushroom to the fork and pilot drill them both together while properly fixed in a pedestal drill and properly aligned to ensure the drill is orthogonal to the forks.
If you do this with a hand drill you are almost certainly doomed to be disappointed.
I placed the screw exactly mid distance between edge of the axle bolt hole and the edge of the fork in the 6 OClock position (my photo is upside down).
I noted that some people with early 7A kits had the original nose gear and at least one (Roberta....who exhibits quite a lot of intuitive rat cunning when it comes to matters structural...but who has absolutely no idea of her taxi speeds !!!) staked at the 9 OClock position. That makes the most sense for that model. However the more recent modified nose gear (which I have) has a lightening hole at the 9 OClock position which changes things.
It will need to be appreciate that the loads on the nose wheel which are then transmitted through the axle and fork are both dynamic and complex. It is possible for those loads to arise from different directions depending on the circumstances meaning that the fork plates will be subjected to loads that are horizontal, vertical and lateral.
I am not making any recommendations here. I am just reporting what I have done. It is up to others to do their own research.
![](/community/proxy.php?image=http%3A%2F%2Fimg184.imageshack.us%2Fimg184%2F3725%2Fscrewdetailkg0.th.jpg&hash=5ae4551583e4165984ba1274b6d7acf3)
