I'm curious what the typical practice is for the annual concerning the nose gear fork. Do you generally remove the fork from the gear and regrease or just check that it moves freely? When you add grease via the fitting, how much do you add? Do you pump until it's full? I haven't seen any guidance on this. I appreciate any information.
thanks for the help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks for the help
