Mycool Well Known Member Dec 23, 2018 #1 Does anyone have a source for non ferrius nutplates? Seems everywhere i look its all metal?!
C cross Member Dec 23, 2018 #2 nut plates I found the nut plates affected my panel mounted compass so I riveted pieces of 1/8" aluminium and drilled and tapped them.
Ironflight VAF Moderator / Line Boy Mentor Dec 23, 2018 #4 ClickBond nutplates come in a wide variety of m,arterial specs - you could check out their online catalog to see if something works for you.
wirejock Well Known Member Dec 23, 2018 #5 I bought a bunch. Aluminum, floating, nylon nutplates. I have to dig out the receipt to find the vendor and part #. Edit Purchased from B&B Aircraft Supplies. Check the "nutplates" link. Last page. Last edited: Dec 23, 2018
Mycool Well Known Member Dec 24, 2018 #6 Great leads Thank you all for the great leads, im looking into all...
