There is none. The KX 155 is the industry standard, the SL30 is better. You could get a Narco, but servicing them is an issue.
Not sure what you mean by IFR, non certified. Other than the big three, King, Narco and Garmin, there are some smaller brands. Garmin is the way to go and they make a NAV/COM in a small package. There are many good choices for "other" separate com radios and even seperate NAV receivers. If you want IFR GPS (stand alone or bundled with NAV/COM) you have to go certified or TSO'ed. That pretty much means Garmin, since they cornered the market.I want to build IFR capable panel and there seems to be many options when it comes to EFIS and engine monitors but what is available in a non certified NavCom with G/S indicator combination?
