Making the inserts, part 1...
Phil,
I didn't have any pics, so when out at the hangar today, I made another panel, so I could pass this along (and archive the steps too). Hope this doesn't get too ad nauseum, but here goes (done in two parts to meet the 10 image max per post):
1. First, the stuff: Hi Temp spray on glue, the insert backing material, outer cover material (I chose fire-resistant upholstery fabric), headliner material, carpet scissors (highly recommended...much better than regular scissors), utility knife (to cut backing), hi-tech measuring device (a piece of scrap with a 1.5" marking):
2. With the panel backing cut (I made mine 1/8' smaller on all sides than the bay it was going in to allow for the material...could have used 1/16", as I have a couple gaps), spray glue on panel and headliner. I traced the panel outline on the headliner just to know where to spray, to save glue:
3. After laying the panel on the headliner and gluing it in place, trim the headliner (no excess needed):
4. Place the panel insert on top of the outer material (both face up), and use your hi-tech measuring device (or eyeball it) and trace an outline 1 to 1.5 inches larger than the panel. Here's where you make sure that any pattern lines up the way you want it to (and do it the same way every time for a uniform look...learned that the hard way!):
5. Here's what the final pieces look like before gluing:
6. Place the insert on top of the cut outer fabric (both face down this time), and spray glue on the exposed edge of the fabric and the panel outer edges:
7. Start from the middle of one side, and stretch the fabric (a little), and press it down on the panel. Work your way towards one corner. Try to stretch it the same amount as you work across, so the pattern stays pretty level (if you have a pattern):
8. For an outside corner, this upholsterer's trick is pretty slick. Bring the material on two adjacent sides together, and as you get to the corner, pinch the material together, keeping it as flat against the panel as you can as you get close to the corner, like this:
9. Then you make two cuts as shown in the following two pictures. The first cut is made low and parallel to the panel. Keep it close to the panel and the fabric below it will lay nicely on the panel and not overlap:
10. Make the second cut almost vertical, maybe angled a bit towards the panel center at the top. You'll end up cutting out a little triangle of material:
