detlef lili
Hello!
I have one GNS430W a VAL760CM and a GMA347. I wired all together and double checked the wiring. The intercom works perfect. Since I want to test the COM, I see only the RX and TX sign in the GNS-430W display but I hear nothing and my hand held transceiver shows me only the TX sign if I transmit and no voice.
What should I do at first?
Best regards
My understanding from Stark is that even if you do not want to change a single setting, you must run the setup software one time.
Thank you for the quick answer, to STICKY1, too!
I thought, that I have only to do this, if I want to change the settings later. I have no software to change the settings, where can I get it from?
I tried Garmin support, but I could not found an answer.
Best regards
Detlef
check your email.
1. I have never used the software. Mine was setup by the avionics tech.
2. You will need to run out the serial conection from the 347.
I got the email
check your email.
Thank you Alton!
I got the email and will try it tomorrow.
Detlef
It works!
Hi Alton! :)
The problem is solved. You must activate the settings.
Thanks again for your help.
Best regards and may be we will meet you anywhere.
Best regards
Detlef::
