WA85
My RV-8 / IO-320 / fixed pitch prop, FWF kit came with Drawing OP 54 and has the EX-00001/8 box shaped heat muff assy that clamps around the cross over pipes in front of the engine.
It requires the heat muff inlet air to ported off the LH front cowl inlet air dam. Has anyone completed their baffling and cowling, and can you post some pictures of how you plumbed the inlet air duct to the heat muff. The FWF kit and drawings are a bit vague in this area.
Note, if you have this new type heat muff, it is very nicely constructed and fits very well over the cross over pipes. It looks like it will provide much more heat than the can type.
However, when you start your baffling, note that the RH aft (#3 cylinder) baffle comes with a pre-cut hole to supply ram air for the old can type heat muff on the #1/3 pipe. You might think about putting a patch plate over it since it will not be used to feed air the new type heat muff, which gets it inlet air from the front. I will admit to not recognizing this and now I need to patch the hole after the fact. Maybe Vans will make a new #3 baffle without a hole in it and a new LH front air dam baffle with a hole to work with the new type heat muff.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
