robertahegy
Moderator/Tech Counselor
I just completed the installation of my new nose gear leg and fork. Van's did a perfect job match drilling the hole for the leg mounting bolt. The machining of the leg was also perfect as the leg fit snuggly into the bore of the mount. I decided to replace the leg along with the fork. I have an aversion to using old parts. It was slightly under sized for the close tolerance bolt, but that was good as I just reamed the hole along with the mount for a perfect fit with a new CT bolt and lock nut with 2 washers.
Along with the fork, I replaced the wheel pant brackets with the new style. They really work nice and make pulling the wheel pant off really easy. I was able to plug the two holes for the axle access, so now I only need the two holes by the wheel pant bracket for removal and inserting the tow bar. I riveted the brackets in and set them in fiberglass, rather than use the screws and nutplates. This is really clean looking and requires only the removal of the two allen bolts to remove the rear half. And I don't need to loosen the axle bolt or jack up the plane to reset the axle torque, as the brackets just slide off the spacer washers on the axle bolt. The pant just slides right off the back with no hassle at all. Love it.
I staked the mushrooms using set screws bottomed out in the mushrooms. They engage in a hole drilled in the fork, but are allowed to float so they do not interfere with proper axle torque. I read Van's notice on the necessity of torquing the axles and I will adhere to that advice. I still think it is a good idea to prevent those mushrooms from turning, though. That is why I decided to use the stakes again.
All that is left now is to finish painting the wheel pant. That was probably the most time consuming because of the removal of the old brackets and installing the new ones. I needed to sand off the paint so I could see the new brackets through the fiberglass so I could drill and clecoe them for subsequent riveting. It was easier the first time because I didn't have to deal with the paint and I could see the brackets much better. I could have reused the wheel pant the way it was, but the new brackets are worth the trouble.
I would estimate the time to R & R the leg and fork at about 3-4 hrs. That would include jacking up the plane, removing the cowl, stripping the leg fairing and wheel pant, removing the fork, removing the leg, reaming the hole for the mounting bolt, installing the leg, swapping out the parts on the forks, installing the new fork assembly, put the leg fairing and pant back on, lower the plane and put the cowl back on. I also set the breakout force, redrilled the cotter pin hole, and cleaned and repacked the wheel bearings. Changing out the wheelpant brackets will add some time, but if you already have the new style or are going to use the old ones, it will go pretty fast.
I replaced the spring washers as well as the large washer under the nut. I purchased extra bolts, washers, cotter pins and nuts associated with the project. A new axle bolt was also installed.
Was it worth it? I think so. The new fork adds some extra clearance and the new wheel pant brackets are sure nice. I fly in the winter with the wheel pants off to prevent snow from accumulating in them while flying off our grass strip. I never had a problem before, but I'm sure this mod won't hurt.
Hope this helps anyone contemplating changing their nose fork.
Roberta
Roberta
