rondawes
I'd like to add a serial input line to my 430W. Is there a way to remove the connector from the backplate so it can drop down to where I can open it up and insert a pin?
When I remove the unit and look at the backplate from the front, I see a screw on each side of each connector. If I remove the screw on each side of the appropriate connector, will the connector come free from the backplate?
