I have a 0360 200 HP Lycoming I need a starter for. The current starter is Factory and it has trouble tuning the engine over. The blades seem to almost come to a stop when on a compression stroke. Like starting a HOT engine!
I would like to purchase a Sky-Tec starter but do not know what model to get.
My choices are NL, E Drive or HT? What starter is good for cranking the engine at a decent RPM? At least an RPM that the prop keeps moving through the compression stroke. I have a Concord RG-35 AXC battery.
I know many of you guys are running 8.5-1 or higher compression and know what starter is best.
