K KJP Member Aug 31, 2018 #1 Hi Folks, I can't find a source for this primer thinner. ACS does not have it and Graco has a $250 minimum order for this gallon of thinner. Any suggestions? Thank you.
P philb Well Known Member Friend Aug 31, 2018 #2 try pilotshop.com $127 Phil Barnette Salt Lake City RV-10 waiting inspection
RV7AJeremy Well Known Member Aug 31, 2018 #3 make your own? MSDS lists the ingredients. Seems pretty expensive for some MEK and toluene.... http://www.aircraftspruce.eu/catalog/pdf/09-00439_msds_en_TR-19_epoxy_polyurethane_thinner.pdf
T Tmartin66 Active Member Aug 31, 2018 #4 MEK for thinner If you are using it for the green AkzoNobel 2 part epoxy primer, I used MEK worked fine and after the primer sets up its tuff. Scrubbed with alumiprep and scotchbrite rinse let dry and prime.
