N NoPlugs I'm New Here Mar 10, 2021 #1 Does anyone know the MS/AN part number for the christen valve end cap (#5). Attachments Oring drawing.pdf 80.4 KB · Views: 283
mach25 Member Oct 12, 2022 #2 Oring Christen inverted oil system The part number for the o-rings in the Christen inverted oil system valve is 63909. You can order from Janette at Aviat (307)885-3151. They are about $1 each and you'll need two.
