pilot28906
I am setting the flap position with the push rod and have the ailrons set neutral and clamped the flaps to them. The problem is the flap overhang skin on the bottom does not touch the underside of the fuse. The flap needs to come up another 2.5* or so. Should I set the flaps with the ailrons and leave the gap or set the flaps at full up with the overhang against the fuse?
Thanks for the advice.
