david.perl
morning from the UK
i just recived my IO360 M1B
the installation instructions are next to useless and the plans in the handbook dont correlate with the rear of the engine
i have one outlet in the lower position that i assume is for the oil feed to the oil cooler, there is a plastic blanking plug on the top of the fitting that goes to the oil filter - this fits the dynon oil temp gauge and there is no other hole for the oil to get back into the engine from the cooler.
Has anyone got a pic of the rear of said engine which shows where the oil return goes?
many thanks
david
Hi David,
The oil return from the top of the cooler goes into the port below the breather:
Hope this helps.
