physics are physics.
How about a half lazy 8 style turn? You'd exit the turn at the same altitude & airspeed at which you entered it, and you'd seriously "cut the corner." Just a thought from a NON EXPERT.
Yep, they sure is.
Think about it. If you just bank hard and then haul on the Gs, as others have noted you would end up exiting the turn having bled off some of your energy. Now you're going to WASTE precious time accelerating back up to full straight & level max speed. As we all know, that last few% of the speed band takes the longest amount of time to achieve.
So DON'T GIVE AWAY that last bit of speed.
If you add vertical to the mix, yes, you will slow down in the process, but you EXIT at the SAME airspeed you entered. NO TIME WASTED. Yes, you slowed down during the maneuver, but you change heading JUST AS QUICKLY and you don't sacrifice one bit of the top end speed on exit. I'm not talking about going straight up. I'm not talking about abrupt maneuvering. I'm just talking about adding a dimension to the maneuver on sharp heading changes.
Am I the only one smoking this crack pipe?!
Groucho, Kahuna, somebody out there who understands a HI YO-YO in the context of energy management, chime in.
Anyone needing advise, go to the RENO air races and watch the PRO'S.... I went this year and when they flew,,,, they were taking large radius turns around the pilons and keeping there elevation the same. Most of the pilots were not banked more than 30-40 degrees. Take this for what its worth. Been there, seen it, etc.![]()
A Yo-Yo/whifferdill is certainly one way to get your turn rate up, but like Kahuna said, there are many other variables you throw in there too. I can't say for sure which way would be faster, but, IMHO, I think you could get within a second of the no-kidding fastest race turn by just varying g to figure out what gets you pointed the right way & at full speed the fastest.So DON'T GIVE AWAY that last bit of speed.
My technique has been to fly a line that is about 1/2 mile outside of the direct point-to-point course. Then I can hold a 45 degree turn and cross over the turn spot, and hopefully not lose too much speed, and not travel too much extra distance.
Good luck, John
As for using the vertical, while you might enter and exit at the same speed, you will not have covered the same distance due to g, angle of attack drag, and so forth. Since a race is about distance to target, forget the vertical for the turn.
A smooth turn with minimum losses and low control deflections will win....
I thought a race was about TIME to target. I would argue that covering less distance in your turn is a very good thing, especially if it takes less time to do so.
Previously somebody mentioned "slowing down for the turn," which I think we all agree is bad due to the lack of acceleration in general at the top end. But if you can "virtually" slow down without losing speed on exit, all the better.
Not in all cases.
Only way to settle this...let's go out and side-by-side it, lock the power in so we're sync'd speed-wise in straight&level, and see who comes out ahead after the turn. I'll turn right up against the pylon and you'll go wide. By the time you roll out on heading and wait to accelerate that last little bit again, I'll already be there, on the inside track, full speed.
You already got good advice. However the "slow down" part is not necessary, turning normally slows you down plenty. If you ever want to slow down, a steep high G turn will do it. That is the basis of the 360 overhead military arrival. Each plane flies over a spot, say end of runway and does a descending high G turn to final, slowing drastically while lowering gear and flaps.Assume speed of about 200 MPH. Have to cross a point then turn 120 degrees to the next turn point. Is there an optimal bank angle? Slow down then turn?
Yup. Flight test. Some RV's will be higher drag than others though. So even if they are matched at a given airspeed it doesn't necessarily mean equal drag profiles once you change the speed.Only way to settle this...let's go out and side-by-side it...
In the late 1920s Jimmy Doolittle developed a technique where he would fairly gradually climb before the corner, then dive as he went through the corner to take some of the g-load off the plane and keep the speed up into the next straightaway. Soon all the racers were doing it.
