jcl777
Active Member
Need advice on how to fit the J-stiffener to one of our tailcone skins. Specifically, the right bottom skin (F-01282-R-1). This is page 10iS/U-06 in the plans.
There is a pronounced gap between the J-stiffener and the skin at the point where two holes need to be match drilled. The left skin had a much smaller gap that was not much of a problem when installing the two solid rivets called for.
No amount of squeezing will work to reduce this gap due to where it is – right at the bends. If we remove the clecoes and push the parts together, then those existing holes don’t come anywhere close to being lined up.
We can’t see a way to make this work. Thoughts?
https://drive.google.com/drive/folders/1FcjAWFcZBmqtw6Ft1JbQicZBh6Ztia6S?usp=sharing
This issue was brought up on this site a few weeks ago. You might try to search for it, but Van’s told the guys with the issue to put a filler plate in the gap. Maybe one of the guys that had the issue will point you to the thread.
Thanks! Not having luck searching for prior thread, but good point about a filler.
