As the title says, I was doing some work on my left magneto, and one of the rubber couplings fell into the accessory case
. This happened just after an oil change do the oil is fresh and clean. (the two issues are not related, I just wanted to state that the oil is clean, Zero hours).
Is there an easy way to locate and retrieve the coupling without removing the accessory case? Will I be able to see the coupling floating in the oil? If I drain the oil will it come out through the drain?
Engine: Lycoming IO-540-C4B5
Anyone have any advice and/or recommendations. Frustrated beyond belief.
john
john
