Thanks Vic
Thanks Vic for doing the inspection and making the process straight forward and not too stressful.
Vic made the entire process as easy as it could be. (Even if he combined the 2 builders names. It was Bill Thomasson, and Brian Urein that were the Atlanta RV-10 inspections. He got it right on the paperwork, and that is all that matters !
Moved the airplane to LZU from my garage 1 week before the inspection! (Took most of the week off to finish it all up)
Will have a couple days to finish buttoning up the plane and installing the interior. Hope to have the first flight by next weekend.
Weighted in at 1692 lbs, with 6 lbs difference side to side with the right wing being heavier with the AP servo in it. Seams to be a little more tail heavy then some of the other RV-10s. Guess I put the paint on thick. Nose 362, left 662, right 668.
Will post some finished pictures once I get the cowl back on.
Total hours so far :2,727
Thanks for all the help I got from other builders in the Atlanta area this week including Gordon, Brian Michael, Brian Urien, Daneil, Steve, and all the others that stopped by and lent a hand in the move and final assembly.
Bill. 99.99% done Pink slip in hand!
