john
Thanks guys. Joe's comments are being looked into. The servo is mounted vertically(item #3 on Joe's list), however, the manual specifically allows this. I have the servo mounted on the outboard(right) wing rib(for easier access) with an 1/8" flat plate mounting bracket(riveted to the wing rib) supporting the servo to minimize torque problems on the wing rib. I have a push a half inch aluminum tubular push rod connecting the servo arm to the aileron bellcrank assembly. The length of travel of the servo arm/push rod has been adjusted for this.
As there are only 3 colored wires(item #2 on Joe's list) coming out of the servo unit, and 3 discreet positions for these wires in the control unit, I can't see how that could be a problem in the wing leveler mode with the aircraft setting solidly on the ground.
The unit has the appropriate response during the "warm up" and you can definitely hear the gyros humming(regarding Pierre Smith's comment). The red lighted indicator ball is in the center position of the LED scale.
Don't know how to determine the center of travel alignment with the stops on the servo shaft. Item #1 on Joe's list.
Joe's "checklist"
Level the aircraft. Done
Disconnect the linkage from the servo actuator arm. Will need assistant
Center the knobs on the control unit.
Place the switch in the center position (T/C)
Apply power to the control unit.
Listen for gyro spinning up. No spin up, bad gyro motor, end test. No problem
Look at display. Red bar should be in center (or close). If not, bad control head, end test.
Place the switch in right position (W/L).
Move the turn knob left and right. Does the servo respond? If not, wiring problem (probably a short or open on the control line), end test.
If the servo moves to one of the stops but responds to the control head you need to rotate the control arm.
If the servo moves to one of the stops, but does not respond, you have bad control head, or much more likely, the control line is not connected/misconnected.
Thanks for the ideas/assistance. I'm not ready to give in yet. This is one problem amongst about a thousand over the past 4 years that I've had to solve. We'll see if we can resolve it. Be back with you guys asap. John
