Off the top of my head
Its a pre 80's nippondenso, 35 amp/12 volt, CCW rotation, external voltage regulation, external fan.
The universal Lester part # 14197
Used On: (1975-73) Honda Civic 1.2L, 1.5L
Alternator wiring:
F = Field (goes to voltage regulator F terminal)
N = Neutral OR stator neutral junction - (goes to voltage regulator S (stator) terminal)
B = B-lead or battery lead (goes to battery/main bat buss)
Voltage regulator:
A = (+) Voltage regulator power, from main buss, 5 amp fuse/CB, "Master/Alternator' switch to 'A' terminal.
I = Ign/light - Ignition terminal on voltage regulator goes to 'charge light', which is connected to positive power supply (main buss). The 'charge light' can be left off. It's optional but recommend it. If you don't want leave unconnected.
Don't forget fuses or fusible links or Circuit breakers where needed. If you need help write me off line. A old Honda car manual will give you an idea of how to wire.
