jbDC9
Hi all,
Anyone need a big a$$ work bench? Rough measurements are 4.5 ft wide and 8.25 ft long, top is particle board. Don't know if it's perfectly flat or straight on top but it's in pretty good shape. Located at Hooks airport in Tomball, T hangars N end. I inherited it from a previous RV builder when he moved on, and now I need to pass it on or chop it up and toss it in a dumpster. Will need a full size pickup or a trailer to move it methinks...
John
edit: I got the size waaaay off, don't know where I came up with 16 ft long, it's actually only 8 ft. Duhhh....
Hi all,
Anyone need a big a$$ work bench? Rough measurements are 4.5 ft wide and 16.25 ft long, top is particle board. Don't know if it's perfectly flat or straight on top but it's in pretty good shape. Located at Hooks airport in Tomball, T hangars N end. I inherited it from a previous RV builder when he moved on, and now I need to pass it on or chop it up and toss it in a dumpster. Will need a full size pickup or a trailer to move it methinks...
John
Sounds like a nice fit for a space I have...I'll measure this afternoon. ...but I'd have to see if I could store it for a while elsewhere.
Any chance you might already be planning on being around Hooks this Saturday morning? I have an 8-10a rental flight, and could swing by to take a gander. :) (Or just stare at your RV.... :D)
Saturday? I'll be around, might head up to Conroe for the EAA 302 fly-in.
Check your PMs...
