petersb
Flap motor works normally when extending flaps, however, when retracting flaps the motor squeels.
This occurs on go around or you can just put upward pressure on the flap while on the ground, to help them raise.
You would think the problem would occur when the flap is fighting the airflow to lower. STRAINGE
