Peter Costick
This problem took a bit of finding. I only discovered it when I added fluid to the brake system, the fluid worked its way through the whole system but the right hand brakes would not work. I tracked it back through part by part until only the elbow could be the issue. I must admit I couldn't imagine how this was until I removed it from the brake cylinder and discovered that a stray rivet had somehow got into the fitting. A messy but successful bit of snagging.
And, hopefully the rivet is still usable. You don't want to waste them! :D
Good sleuthing indeed. Who woulda thunk?
NASA tests show that brake fluid has no negative affect on rivet function. Rivet saved!
It was a flat head. Tried to post a pic but foiled by Android.
Rivet was saved but hydraulic fluid was tragically lost....
