Mark Dickens
Patron
Since I know just enough about electronics to be a hazard, I need some help from the avionics gurus. I want to install a mute button for the comm radio output from my 650. If I used a DPST switch for this, I'd need to shunt the audio into a resistor to provide a load, right? The GTN-650 installation manual says that it supplies 100mw into a 500 ohm load. So, I'm thinking that bridging a resistor with those specs across one pole of the mute switch would work? Am I even close?
You can just open the circuit, no harm done (same as pulling the headset plug.
Even better! Thanks! Somewhere in the dusty dark corners of my brain, I thought I remembered that the output had to go into a load...
