I've worked extensively with Muriatic acid in an industrial setting. The vapors will indeed corrode steel and aluminum...and rather quickly. My advice to you would be to remove all tools and parts from the workshop before starting the acid treatment. Invest in a good respirator (not the cheesy 3M paper ones) before working with the acid and don't take it off.prkaye said:I've read that Muriatic acid promotes corrosion of steel. What about our aluminum alloys? I may be etching my floor to prepare for a coating, but am worried that the vapour from the acid may lead to corrosion. Is this a valid concern?
