What radio?
Steve Sampson said:
Can someone point me in the right direction please?
I am beginning to think about avionics for an RV4. Since I built a -9A the number of instruments outputting voice has increased. This time I might have:
Radio
Dynon 180
Garmin 496
ACS AOA
IPOD
That is radio + 4. How do I merge all of these into a headset with some degree of priority? I am only seeing intercoms that can cope with the radio +2.
Some radios like the Icom A200 have several 3 or 4 aux inputs, Garmin's don't. Also I'd encourage you buy an intercom that allows an aux stereo music input. A cheap intercom with an aux mono input is OK, but I would not scrimp on this if you want music (that is my opinion).
If you have a Garmin with out the aux inputs, you can do as above and gang all the alerts together with resistors and/or capacitors. I personally like a little pre-amp mix board kit for about $10. Aeroelectric has an expensive board kit he sells that will cost you about $60? It really an overpriced kit.
The nice thing about a pre-amp mixer is you can "tune" and balance the inputs and absolutely isolate them. However people have lots of success just jamming the wires together with a little resistor in there to isolate or balance gain (volume). I do like that it is passive, lighter and cheaper, so its worth a try, but I know a little mixer with op-amps to isolate and balance will work and be more adjustable.
I'd buy a stereo intercom (PS Engineering) that can handle a stereo input and headsets. I'd recommend DRE engineering intercom's but they went belly up. If you are cheap, on a budget, the intercom is not the place to save money IMHO, because you use it every flight. Its basic and critical to your enjoyment. I'd avoid mixing music and alarms together for many reason. There are many ways to skin the cat (who says that anymore, I guess me
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
). The thumbnail on top my architect (with an Icom), with a Garmin I'd go this way (click to enlarge).
Here is a typical mixer (hidden under panel):
http://store.qkits.com/moreinfo.cfm/FK652
Basically its an audio panel you can hide under the panel, no switches or anything. Comes on with master buss. Set and forget. You could have it so its volume "pots" are reachable under the panel. There are a half dozen electronic kits you can buy for $8-$14. The one above is just one I picked at random. You can go out an buy a little multichannel op-amp and the other parts, but these kits are cheaper.
