Weight a minute...
I need to get my 6A out of a muddy runway. I'm going to remove the wheel pants first. Just wondering if anyone has an opinion if 100 pounds in the baggage area would help by lightning the nose wheel, or hurt by adding extra weight?
I wouldn't pull your wheelpants as it doesn't change much. Better plan is to lower your tire pressure and as mentioned above, very light load.Use an ATV or lawnmower as a tug. Empty tanks and put a 100lb bag in baggage as mentioned. Tow slowly and take care not to put too much stress on NW.
Towing backwards is preferred. Use sand or kitty litter to solidify the area.
Flying out? My strip stays gooey during the summer months and after over 1000 takeoffs and landings I have found a few tricks that work well. Before you do anything, take a tractor or ATV onto the strip and survey the best spots.
My tricks:
1. 380X150X5 tires. Big improvement.
2. Bush Pilot takeoffs ie, no stopping, keep power up advance to WOT during your 180 degree turn at EOR.
3. 10 degree flaps T/O. If you have manual flaps you can apply full flaps at 50 knots and get airborne in ground effect then retract as you accelerate.
4. 500X5's? lower tire pressure to 20 PSI.
5. Nosegear? Keep stick full aft throughout taxi and takeoff. Hold nose off as soon as it will "fly". Also helps get airborne quicker.
6. Heat of day/Cold of day: Take off mid-day or dryest period if possible. Ground is softer in AM unless below freezing which as mentioned helps too.
Discretion is the better part of valor, if the ATV gets stuck, you will too...
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
V/R
Smokey
